Import data from other browsers on ipad pro
  • 1 பதிலளி
  • 8 இந்த பிரச்னைகள் உள்ளது
  • 363 views
  • Last reply by Medhasree Suram
Hi, there is no import data button on general settings on ipad pro menu. How can i import passwords, bookmarks and history from brave/opera/duckduckgo/chrome/edge on ipad pro to firefox? How can i download history, passwords and bookmarks files for backing up firefox on ipad pro Thanks a lot
Hey there! I understand your concern about importing data from other browsers to Firefox on your iPad Pro. Currently, Firefox for iOS doesn't have a direct import option like the desktop version. However, you can manually transfer your bookmarks by opening each browser and bookmarking the same pages in Firefox. Unfortunately, importing passwords and history directly isn't supported due to iOS limitations. To back up your Firefox data, you can create a Firefox account and sync your data with it. This way, if you ever switch devices, your data will be safe. Hope this helps you out! If you have more questions, feel free to ask.
